Keller "Killer" 300M Ball Joints for Polaris
Discount code from our already low price:
Keller Ball Joints $4
Use the link below to order:
Replace your weak OEM ball joints with these "KILLER" 300M replacements by Keller. Designed to be greasable and can be adjusted for wear! These ball joints are manufactured in the USA, and are backed by a LIFETIME warranty. against breakage!
Keller ball joint adjustment procedure:
Kellers just need to be properly adjusted and greased. Use RCV CV grease in them when assembling for best results. Re-grease periodically with the best grade of tube grease you can get. The initial set on the Kellers is done dry so that there is just a little resistance to movement. Disassemble the joint by taking the cap off, grease and put them back together with RCV CV grease. Pack them as full as you can. RCV grease link.
Sold Individually
Fits Polaris Models:
Call if you don't see your vehicle listed. We stock all of Keller's Ball joints.
Fitment:
Turbo R upper
Pro R upper
Pro XP
Turbo RZR and XP1000 RZR (lower and upper)
Turbo S
Pro XP
570 Ranger Crew Full-Size 4x4 2015-16
570 Ranger Full Size 4x4 2015-16
900 Ranger Crew 4x4 All Options 2015-16
900 Ranger XP 4x4 2013-14
900 Ranger XP 4x4 All Options 2015-16
900 RZR 4 4x4 2015-16
900 RZR 4 XP 4x4 2012-14
900 RZR 4 XP Jagged X 4x4 2013
900 RZR 50”/55”4x4 2015-16
900 RZR 60” 4x4 All Options 2015-16
900 RZR S 4x4 2015
900 RZR XC 4x4 (55”) 2015
900 RZR XP 4x4 2012-14
Brutus HD HDPTO 2014-16
Ranger Diesel HST 2014
Ranger Diesel HST Deluxe 2014
Ranger HST 2015-16
1000 General 4x4 2016+
1000 Ranger Diesel 4x4 2015-16
1000 Ranger Diesel Crew 4x4 2015-16
1000 RZR 60” 4x4 2016
1000 Ranger (DOES NOT FIT 2018+ Ranger 1000 with the new body style lower A-Arm. Still fits the upper A-Arm)
Email or call 801 367 1395 with questions.
Made in USA
SPEC High Temp CV Grease by RCV
Free shipping in the lower 48 states. SKU: HT1LF-SPEC RCV SPEC CV Grease is specially formulated for extreme racing applications where heat can be an issue. This is required for use in all CV joints in our UTV program and race CVs, but can work will all RCV CV joints. Standard tube size - 16 oz...
www.proutvparts.com
CV Grease by RCV
Free shipping in the lower 48 states. RCV High Performance Synthetic Moly CV Grease is specially formulated synthetic grease for extreme applications, and is recommended for use with all RCV CV joints. Contains a ridiculous amount of moly! # HT1LF-1 RCV SPEC CV Grease is specially formulated for...
www.proutvparts.com
Sold Individually
Fitment:
Turbo R upper
Pro R upper
Pro XP
Turbo S
Pro XP
900 RZR S 4x4 2015
Ranger HST 2015-16
Made in USA
