Yes, same dyno:ride:NICE!!!! .... same dyno they did the baseline on with the stocker?
STM Rage VIII. This set-up is in my 2 seater. This is one bad bitch lolAskin. What clutch set up are you running ?
You want to get the drum rolling before you stand on itdumb question but why doesn't anything log until 10mph and where is the stock run for comparison
Thanks, I will post the tq results later they are off the charts.Way to go Askin.
Congra in ur result.
Yup hold on is an understatement. I took it out for spin yesterday and I was amazed at just how hard this thing pulls out of hole. Even at 40 mph and jumping on the gas it’s a handful. I look forward to October out at GlamisWOW!
Thats huge, I am so impressed with those numbers, HOLD ON!
Thanks!
About 6 miles LOL. Not sure and would not try it, you know as well as I do the stock cranks are not made for High boost. I ran the stock crank at 14 Ibs. and it held up, but I would not recommend doing that.How long would a stock crank last at 18 lbs of boost?
Makes since. I thought you were going to be running at 18 psi all the time.About 6 miles LOL. Not sure and would not try it, you know as well as I do the stock cranks are not made for High boost. I ran the stock crank at 14 Ibs. and it held up, but I would not recommend doing that.How long would a stock crank last at 18 lbs of boost?
