Hey guys, don't hammer me too hard. I am new to SxS and not a great mechanic. But, I am learning... Installed my own winch, S&B separator and a few other things. Now I am installing my a arm and trailing arm guards from Factory UTV. In order for me to get the rear guards on properly, I need to remove my rear tire because I need to drill a hole thru my trailing arm.
I have the Pro eagle small Co2 jack. I can only lift it so high with this jack... Problem is my suspension sags so much that I cannot get the tire off the ground. Whats the technique here? Do I put a ratchet strap on one of the bars above the axle prior to lifting the car up to reduce the sag? I want to ask here because I am not sure if I will damage anything doing this. Thanks in advance for any help on this
