1 - 4 of 4 Posts
What is the best place to but the jack stands, front == back and can you put all 4 up at one time?
i would guess one under each end of each rock slider. in front of the rear tires and behind the front tires. wide as possible
I was just battling this question last night! I've got my rzr torn apart doing a top end, so while its down I want to take care of the skid plate, a-arm bushings and u joints. I usually try to support the rzr on the frame as much as possible, its the most rigid support for the vehicle. My problem is I'll have to support on the a-arms, drop the skid plate, set it back down, jack it up and support it on the frame to work on the a-arms. That's a lot of up down up down lol
When we do skid plates we tip it on it's side on tie it off to a post to stop it going all the way over you might have to many loose parts with the motor torn down.
1 - 4 of 4 Posts
