1 - 5 of 5 Posts
I don't have a ton of accessories, but I hate the cluttered look of 3 or 4 terminals on each post. Do you know of any bus bars that separate the positive, negative and ignition like the OEM, but have multiple posts per section?
I think my other option would be to run a jumper off each terminal down to a separate bus bar for each function. Lots of hardware under the hood that way.
Went this route and worked wonderful.
Team Concours Relay Fuse Distribution
658396
658397
craigstumph
Here is one made for your RZR:
658402
This was my solution. 6 position hot all the time. 12 position switched with ignition. 12 position ground. 120 amp 100% duty cycle, ignition switched relay. All power run to battery and fused at terminal. Mounted under dash so it stays relatively clean.
658483
1 - 5 of 5 Posts
