Yeah I know.. I should have been more clear. Lol. I wanna do cat delete on the 16 muffler and then put it on my 19. Just wasn't sure if they were exactly the same.
From what I can tell. The part numbers are different. I guess I could pull the 19 muffler off and compare it with the 16. I wouldn't think the inside baffles would have changed.??
For those of you out there with an older turbo muffler laying around. The 16 muffler mounts the same as the 19. I did a cat delete on the 16 muffler and put it on my 19 turbo, fits perfectly.
I put 32" tires on my 2016 Turbo and it feels super top heavy like it wants to roll easy I am thinking with the added weight I need to stiffen to suspension, anyone run into this issue and if so how do I stiffen the suspension they are the fox shocks.
Just thought I would share my experience so far with my New Bikeman tune. I went with Bikeman since I have used their snowmobile clutch stuff in the past with great results. They are also the sponsored Polaris factory race team so I feel really comfortable with their kit and ability to tune the...
A while back there where several threads about BOV that had a lot of misinformation in them. I will try to clear up some of the misconceptions show how to setup a inexpensive BOV for use on the XPT.
1) All Blow Off Valves / Diverter Valves work the same way.
2) A BOV and a Diverter Valve are...
Those of you that have replaced your blowoff valves..
Which one did you buy?
Is there a real difference between them?
I see some around $100 and then i come across some that are nearly $200.
