1 - 3 of 3 Posts
I have a 16 RZR 1000s and the instrument cluster will not light up. If I jump 12v to the #1 pin on the cluster it still will not light up. Additionally, I am only getting 2.5v to the number #1 pin from the ECU. My question is: If I jump pin #1 with 12v from the battery and ground pin #5 with a ground, shouldn't the cluster at least light up? Trying to determine if the cluster is bad. Any help would be appreciated.
I don't have a 2016 schematic, but 2015 MAY be similar?
Pin #1 is a CAN circuit, so 2.5v sounds correct.
Find a 2016 schematic to verify, but you may need 12v on pin # 3 or 4.
1 - 3 of 3 Posts
