Installed new custom bushings from JCCAPRI
1 reading
10K views 27 replies 10 participants last post by  jccapri
My front aarms were sloppy at 450 miles. I religiously greased with green grease. When I pulled them off I found lots of grease but the bushings were also cutting into the pivot tubes. They were scored all the way around on the ends about 1/4" down the tube, where that little lip sits. The oem design seems very detailed but not very supportive. There was no contamination in the arms, just lots of green grease. I don't think I could have done anything better. I greased it by lifting the front end up off the ground too.
I looked at the various options and researched on the Polaris sportsman forums. I found a fellow jccaprijccapri@yahoo.com producing bushings. He has a good number of guys running these on the PolarisATVforums and no one has worn a set out. Since the bushings are common over many of the Polaris atvs I figured I would give it a shot.
Jon is easy to talk to and honestly just trying to make a good product. (I should say I have no affiliation with him other than buying a set of his bushings.) The parts were of good quality and he hand makes them. I cant attest to their longevity yet but seems a good alternative to other more expensive bushing sets or simply replacing with OEM.
I have never replaced bushings but it was very simple.
-Unbolted the shocks
-Removed all the screws out of the front bumper, left the plastic clips
-Pulled out the bottom AArm bolt and dropped it down
-Flushed the AArm tube with carb cleaner and cleaned like a shotgun barrel
-Work your way around the unit in the same manor, youll have to pop the clips out of the bumper on the side your working on but I found it easier to not fully remove.
-Removed zirks as they penetrate into the tube and put a lock washer under it
-Reinstalled
When reinstalling I noticed that 'tight' was not tight enough. For the heck of it I tried the torque wrench and set it to 37lbs. I wasn't bearing down on it as much as I should have (per spec). That torque removed all slop in the front aarms.
You don't need to do anything to hubs/axels anything. Total replacement, cleaning, removal and reinstall of the guards was about 2 hours.
Jon's bushings don't require any lube. I'm going to run 1/2 the arms dry and grease the other and see what happens. If your interested shoot him a mail or look him up on the polarisatvforums.
jccapri bushing complete kit install with pics and vid. - Polaris ATV Forum
Whats funny is now I hear the brakes clattering away again. I think before the aarms dampened it :)
Time will tell how they hold up but Im optimistic based on the abuse the 850XP guys dole out on these.
...........Jon's bushings don't require any lube. I'm going to run 1/2 the arms dry and grease the other and see what happens. ...
plastic bushing may be tough as nails but it is still pivoting on a steel shaft and and steel mounts. If it pivots there is clearance and if there is clearance grit migrates in and when grit gets in wear occurs.
RZR suspension is pretty basic. It has to be lubed. Besides in most regions zinc plated bolts and coated mounts rust pretty quick.
Do you make these for the rear bearing carrier or for the a arms only? The top busing is the same as the lower rear a arm but the lower bushing the bearing carrier is not the same as any other bushing on the rzr
Just reach over to him on the Polaris ATV forum or email him. The moderators must have removed his threads. Must be a vendor thing although he just hand makes them on the side, or did when I got mine. Im sure the UTV Inc and Super Daves is good stuff too, just wasnt in the piggy.
JCCAPRI, Merry Christmas to you too.
As an update to this thread I have had a bad diff seal (you can search for the saga). Suffice to say the front of the rzr has been dismanted a few times. The front bushings are as tight as when I installed. I suppose about 300ish miles on them.
Hoping over Christmas break I can put more miles on pulling kids in the snow :)
Hey Jon,
I don't mean to hijack your thread. I purchased your bushings for my 550XP Sportsman. They installed easy and up to the time I totaled it, they were working perfect. No wear at all. The stock ones where shot in about 500 miles. I had way more miles on your bushings before my bike met its demise. Why I now have a RZR...lol
Anyone in the market for bushings should give jccapri's a good look. He shipped quick and has a great product. You can bet when my stockers wear out I will be giving you a call...
TBS
Well. I am not going to say I like it better. But at this time it suits my needs. I have a girlfriend who likes to ride with me. They are a blast no doubt, but I miss my XP.
TBS
#22 ·
Remove the other bolt first and see if the control arm will twist just enough to let you either remove the bolt or pull it far enough back to remove the entire control arm. I just replaced all of my lower control arms and was able to remove all of the bolts, but the rears needed a little twisting and finagling.
Jr
