I did a search and found nothing... Are there inner tubes aval for the 570, 800, and 900 oem rims? If so where do I find them. Thanks for your help!!!!
Are you saying to use a patch or that you can't patch if you have a tube. We had a 900 slash a hole in the side wall last time and could not get a patch or slim to stop it from leaking. This is why I think a tube would work instead.
What's the issue with tubes? Seems like a great idea if you get a flat that can't be fixed with a patch
Take it to a tire shop that does vulcanizing. Also patch plugs work pretty good. A tube would work good until you get a hole in it on the trail. Can't hardly break down a tired to patch a tub there. I've seen a lot of sidewall holes but none that be couldn't eventually plug enough to get back to camp.
I have had a tube in my rear tire for over 500 miles with no problem.
It was in there wher i got my 900. someone pinched the sidewall ,inserted two plugs and a tube. still in there today with no problems (yet.)
