1 - 3 of 3 Posts
I went to start my rzr to ride yesterday and it wouldn't stay running and when it did it was missing and carrying on. I did and oil change, gas check, new plugs. Didn't help. Checked my injectors both are good besides the plug. My question is how do I replace the plug? Is it a new wiring harness or is it a cut and splice kind of job
Have a picture? You may be able to de-pin it and put it in a new plug. I actually have quite a few of these connectors (Injector Dynamics uses the same connector and I've used a crap ton of their injectors) that I'd send for the cost of shipping.
I had a wire break lose right at the base of the plug. Re soldered and all was good. I would think if the plug itself is bad, you should be able to fashion a new one on as mentioned above
1 - 3 of 3 Posts
