81 - 93 of 93 Posts
Discussion Starter #81
Re: 4 Sale Holz PRV Oil Pressure Relief Valve
Holz Racing Products Adjustable Oil Pressure Relief Valve (PRV)
Replace your stock PRV bolt with this adjustable one so you can monitor and tune for optimum oil pressure.
We have found the stock oil pressure settings to be inconsistent between different RZR motors.
Some 800 motors with oil pressure that is too low will inevitably experience problems later on that may not have been detected or remedied without the use of an Adjustable Oil Pressure Relief Valve.
This part is a must for remote oil cooler set-ups. It is common with the addition of the longer oil lines and increased oil capacity for the engine oil pressure to drop.
Recommended for all motors especially those with high performance mods.
Includes:
- Adjustable PRV bolt
- Gauge w/ hose & fittings
- Detailed instructions for setting optimum oil pressure
Shipping Weight: 1lb.
The instructions included with the PRV explain how to adjust the oil pressure... Be sure to read the instructions and install and adjust the PRV per the instructions...
$63.00 shipped...
In Stock...
Discussion Starter #82
Includes:
$63.00 shipped...
In Stock...
Discussion Starter #83
Includes:
$63.00 shipped...
In Stock...
Discussion Starter #84
Includes:
$63.00 shipped...
In Stock...
Discussion Starter #85
Includes:
$63.00 shipped...
In Stock...
Discussion Starter #86
Includes:
$63.00 shipped...
In Stock...
Would my wifes 2008 rzr stock motor benefit from this adjustable pressure relief valve? Engine has approx 5000 miles doesn't burn a drop of oil and I always change oil at or before the 50 hour mark. Always run PS4 plus with a Polaris filter.
Sent from my iPhone
Discussion Starter #89
Sent from my iPhone
It would benefit from having a constant higher oil pressure than without the PRV...
Tim,
Do you still have these in stock?
Holz no longer sells them.
I'd settle for Adjustable PRV Bolt without guage.
Includes:
$63.00 shipped...
In Stock...
Discussion Starter #93
I'd settle for Adjustable PRV Bolt without the gauge.
No I don't.
81 - 93 of 93 Posts
