So I Removed the tb to clean it and without thinking I removed the sensor. I have a service manual and I've read a lot of threads on here on how to set it without the special tool. My sensor only shows 2.66 at w.o.t. I did not adjust the
idle screw as it idled fine before.
I probed the yellow wire w/red and black to battery neg. Set the sensor at .53 and tested. (Idled and reved up fine). Re read the instructions and Readjusted to .72 (would not go any higher). Test ran, Idled poorly and low.
Is it the end of the world if the sensor does not climb to 3.77 or so?
Is there an easier way to do this w/out dragging it down to the dealer?
Thanks
Thanks
