My mind is going NUTS!!!! I have been reading the thread on the new progressive springs from Makin Trax,and Steve seems like a nice enough guy that I didn't want to steal his fire by putting this in his thread,but I can't help but bringing this up AGAIN....I am not trying to make him look bad by any means, but since adding pre-load to change spring rate is always brought up as an answer as to why progressive springs will be such an advantage,I can't help but bring it up again....
If I am wrong in what I have always understood about suspension and how it reacts to pre-load,then I have something to learn,but if I am not, then maybe others will become more aware of what they can or can't do with pre-load adjustments..
So here we go...My ? is, how is the rate changed by adding pre-load? In order for rate to change, the spring would have to be compressed more...I URGE any of you guys to do an experiment with your current shock set up,whether stock or aftermarket...
Set them at 0 pre-load,bounce the machine to settle the suspension,and measure the spring length as well as machine height....Then crank the pre-load all the way up,settle the suspension with a couple of bounces, and re measure...Post back with your findings...
You will find that with ANY spring,the spring length never changes, only ride height...How does this make the spring rate change? I understand that this will allow the spring do be different in the last area of travel just before the shock bottoms out...The distance is determined by how much preload is dialed in,but considering the shock angle,2" of preload would be a VERY minimal distance that you would ever feel any difference,Not to mention that if a spring allows you to put that much pre-load in it, it isn't set up correctly to begin with...A correct length spring should only give 1" or less pre-load adjustment before the spring goes into coil bind which is a BAD thing...This is where the coils hit each other before the shock bottoms out...Any other set up is not optimal, and you aren't getting the full use of the spring in any area...Having a spring with that much adjustment in,especially with a progressive spring,would mean you aren't getting optimal use of the spring with lower pre-load, because there is still alot of spring left after the shock bottoming out,or with pre-load cranked in, you aren't getting optimal use of the droop that you should have in your shock because it has you jacked up to almost full extension on the shock...
Just throwing out some numbers,If the weight your machine puts on the front shocks is 400 lbs,that compresses the spring 1"...In order for that spring to compress more, thus changing the rate,there must be more weight put on the spring...If the shock is not at full extension, which it shouldn't be,then adding pre-load does not add more weight to the machine, so it can't compress the spring more...The only thing it will do is cause the shock shaft to be extended the same amount,thus raising the ride height but doesn't do anything to the length of the spring or the spring rate...
If I am wrong in my theory,please educate me...If I am right,then let's stop believing that spring rate which translates to ride stiffness/softness can be adjusted by a simple turn of a knob...The suspension world would be a much easier place to live if that were the case,and many hours of testing and tuning would be cut out,because finding the right rate would be easy..Just put on something close and use the adjuster to take care of the rest, but it's not that simple....
Like I said, I do understand that adding pre-load will translate to stiffer spring in the shock just before it bottoms out,but most people will never feel this in the pants, because it is so minimal...You CANNOT make the general ride stiffer or softer by adjusting pre-load....Just something to consider before spending lots Of $$$$ on springs with the idea you will have full adjustability in your ride ...
Please reply
Hoodlum
Please reply
Hoodlum
