How to attach standard harness
2K views 2 replies 2 participants last post by  Chopstix Kid
Picked up a Turbo S4 cage on the cheap a while back. I was planning on getting some Click-6 for it but life happens and that will have to wait. Anyhow, before I put the S cage in, I want to make sure that I won't have any issues using installing my current Dragonfire 4-pt harnesses. I have factory seats with pass-thrus installed and the harnesses are strapped around a harness bar.
So I'm not sure if I can simply wrap them around the S cage bars or if I need to get bolt-in harness tabs. 4 seater so I have to do front and back. And also looking at grabbing a SATV rear windshield with the harness slots so needs to work with that too. Thanks!
Ok cool, wasn't sure if I could use standard bolt-in harness tabs with those. Assuming they run over the top of the bar like the OEM harnesses, will that make them too high to use the aftermarket seat pass-thrus I have on the OEM seats? Or will it be safe to simply come off the bottom of the cage tabs?
