I have heard true 27" tires will clear as well...I know that 28" Outlaw radials require major remolding of the front fender wells. 27" should be ok without rubbing on the 570.
the 26" bighorns fit just fine. no rub at all, anywhere. but they are damn tight in front when flexed, i don't know if any more would fit without modding floorboards.
Do you have a lift on your 570?the 26" bighorns fit just fine. no rub at all, anywhere. but they are damn tight in front when flexed, i don't know if any more would fit without modding floorboards.
front at full flex(i have no sway bars):
yes, factory S takeoffs.the 26" bighorns fit just fine. no rub at all, anywhere. but they are damn tight in front when flexed, i don't know if any more would fit without modding floorboards.
Are you running 12 x12 rear and 9x 12 front?
all stock.Do you have a lift on your 570?the 26" bighorns fit just fine. no rub at all, anywhere. but they are damn tight in front when flexed, i don't know if any more would fit without modding floorboards.
Great !actually feels faster/quicker/more powerful on these.
climbs like a champ.
for a budget setup, it is amazing.
0 regrets.
as far as i know, the stock S/Le wheels are the same offset as steel wheels.Great !actually feels faster/quicker/more powerful on these.
0 regrets.
Last question, are the rims off set the same on what you have as the stock 570 rims?
Thanks for all of your help! I have a set of bighorns on my grizzly that I am selling that I will keep for sure now.as far as i know, the stock S/Le wheels are the same offset as steel wheels.Great !actually feels faster/quicker/more powerful on these.
0 regrets.
i know it sure didn't make it look any wider. maybe an inch due to adding an inch of tire width.
Good deal!I Put a set of stock Big Horns off my 2013 XP4 onto my 570 and I dont have any issues with it.
