I got the opportunity to swap my 09 stock engine for a 2010 engine with a Holz BB and Muzzy's. ("I Jumped IN It!")
I looked at 820-840 BB, but all you get is a bored out cylinder and large pistons. The Holz Kit is a complete package (Pistons, Ported Head with Bigger Valves, Cam, 48mm Throttle Body, Increased Oil Pressure, Re-flashed ECU, Clutch Kit) and it is as reliable as a stock engine. The power-band is down low, you are not on and off the throttle, you feather the throttle. Rev-limiter is raised to 7,000 or 7,200 rpm. I trail, mtn, crawl and mud, I rarely need low range. (No Dunes in TN)
It is the high compression version, so I am running a mix of high test and racing fuel.
The engine was built to drag race and it ran 9.1 seconds at 68 mph through an 1/8th mile. It has 48hrs and 428 miles when it was installed in my Rzr S.
When I decided to do the swap, one of my buddies asked, "What if it has too much HP, I replied "No Such Thing!""). I've lost about 15 miles per tank of fuel, but I added a 3 gal Roto-Pax fuel can, so not an issue.
NO TINKERING, RELIABLE,AND STEALTH!
Other Modifications:
Chopped Cage
Tony's Toys True 3" Lift
Makin Trax Springs
Hiper Dakar 14" Carbon Fiber Beadlocks
30" Super ATV Dominators
Engine Ice Coolant
Winch
HID Fogs and Headlights (Backup Lights)
Dakota Digital Gauge with Water Temp/Oil Pressure
Mojave Heater with Custom Mount
Air Box from DL Machine
DFR 4 Point Harnesses
Pro Armor Doors
EMP MR-10 Windshield
Tagged as a Medium Speed Vehicle, no issues with riding too the Mtn's.
:icon_rockwoot:
:devil3:
Chopped Cage
Makin Trax Springs
Engine Ice Coolant
Winch
Pro Armor Doors
:icon_rockwoot:
:devil3:
