1 - 11 of 11 Posts
I just wanna ride
I see a lot of RZR with after market hoods, grills and holes cut/drilled in the hoods. Do they real help cooling system?
I never had any trouble but I bought a grill kit for my hood anyway. IMO in most cases you don't need it
I was thinking about drilling some holes in the hood also.. couldn't hurt. Also just found the utv inc and utv tech grills that are fairly cheap.
I just wanna ride
This is what I got. Nice kit, very well made, I like it a lot
holz
◄►STARS & STRIPES◄►
The simple answer is YES, anything blocking air from going through the radiator is going to cause your RAZR to have to run the fan more and have a higher temp.. That's why in cold climates people put cardboard over parts sometimes all of the radiator so that the vehicle can stay warm in extremely cold weather... There was a reason for the design change for the 2011 RAZR's, more airflow... There is nothing fancy or special about it..
Since I am re-building my 08 from the ground up, I have already picked up the fiberglass to build my new (secret) front end that will tie in with my patriotic fullbore....
i cut slots in my hood and when the fan runs you can feel air flowing through them. so yes it helps. more air flow = less strain on the cooling system.
Depends on where and what you ride in.. Mines overheated a coupled of times. It was trail riding using a lot of Low gear with the radiator muddy. I not only have a Holz front grill but I also run Engine Ice for coolant. It helps keep the temps down. If your running around in High gear out in the open air and you dont get in much mud you probably don't Need a front grill. It wouldn't hurt anyone to have one though..
1 - 11 of 11 Posts
