1 - 18 of 18 Posts
Looking at 6” portals for my 2020 Highlifter 4 Seater. Trying to decide between the superatv ones and the HL ones. I like the dual idler gear setup on the HL. Also the 60% reduction in the HL. Anyone know of any issues with either setup? I plan on running 37’s. We don’t ride fast. Their about the same price.
I run SATV portals and have no experience with HL portals. I will tell you that given the HL OEM gear reduction 60% is too much for 37s. I would go with 30% or 45% at the most.
When I bought mine the main factor for me was where they were made, Hi Lifter bought SXS Gear and back than SXS Gear was manufactured in Flint Michigan, good ole USA.
You need to pick your setup and build around it. Calculate the gear ratio vs tires. Why do you think dual idlers are necessary?
And SXS gear made a piss poor product...ask me how many gears I busted. So none of that matters.
I have over 1000 miles on mine, zero issues, my dad has super atv portals with over a 1000 miles with zero issues, for me it was just a personal choice on where I wanted my dollars to go. Anything can be broke.
You said you based your decision on "HL bought SXS Gear". SXS Gear was a one man show (Chris) and the design and materials where piss poor. So bad I use to carry 2 sets of spare gears because the teeth would shear off. Finally I had to give up on them because they broke so often. I have ZERO experience with the new HL portals but I hope they are not based on the SXS Gear design.
I was running portals and big tires LONG before most even knew what portals were, way before SATV or HL made portals. I am glad to see more companies getting into portals so customers have a choice and it will help develop the product to better levels.
I said when I bought mine, which was before Chris sold to Hi Lifter.
SXS gear and Chris have nothing to do with the new generation of HL portals. They are all designed and tested in house now. I have the 60% dual idlers with 38s.
That’s why your my hero Joe. I ran portals in late 2014/early 2015 but they still weren’t reliable at that point. I wouldn’t run portals if you paid me to at this point. Absolute junk. But hey if you wanna be stranded somewhere with a heavy machine sitting on a locked up portal be my guest. Lol.
Discussion Starter #16
How do you like them so far?
1 ride on them I love them. With 35’s in low it crawls up anything. i did notice yesterday though when I had the front end off of the ground I grabbed the top and bottom of wheel and shook it hard to check the bearing and I have a teeny tiny bit of play in what looks like the bearing. Both sides do it. I have to shake it pretty hard so I’m not worried about it. There’s no thud or leaks so meh. But yea I recommend them.
I had to re tighten my axel nuts twice before I got them tight enough, now they have been good for over 1000 miles so far.
Discussion Starter #18
I don’t think this is the axle nut not being tight enough. I think it’s the bearings. I will retorque tonight before I put on tires. I torqued them to 120 like it says. Maybe I’ll up it to 130?
1 - 18 of 18 Posts
