1 - 4 of 4 Posts
So the time has come where I have to start replacing a bunch of bent parts on the machine but am a bit confused as to which parts will fit. My question is... Does the Highlifter share the same length front arms and rear radius arms as a regular XP? or would I have to look at xp Turbo parts for the correct fitment. Most of the sites that I have been to do not list Highlifter specific parts.
The suspension is the same as for a XP1k. The only difference is the radius rod bolt size. Depending on your year model they could be 10mm or 12 mm. I believe all 18+ models are 12mm.
My 17 has 12mm rod bolts
1 - 4 of 4 Posts
