1 - 5 of 5 Posts
Huge difference in tubing diameter and weight. Much stronger than stock and the added advantage of 1 1/2 inch forward to eliminate my sand tire mohawks from rubbing
651768
Huge difference in tubing diameter and weight. Much stronger than stock and the added advantage of 1 1/2 inch forward to eliminate my sand tire mohawks from rubbing View attachment 651768
I can see the difference in this pic
So if I've been following correctly you have replaced the front and rear upper and lower all together.
You said that you gained about 1 1/2"
In the front for ground clearance.
Anything in the rear?
And we're all 8 just unbolt and bolt on? Or did you have to adjust anything like suspension or alignment
You are correct. I can gain more on the rear if I did the rear lowers but have not done so as of yet. All bolt on and I did have to re-align once installed. Pretty simple process and it is driving really well!
1 - 5 of 5 Posts
