1 - 8 of 8 Posts
I installed this kit 1.5 years ago and have never found a good set up. I have changed it so many times I can't even remember how it came from a Dale. Does anyone have a starting point for me?
2012 900
26 STU #1's
No power adders
Right now I have the big bolt with 2 big washers at the heal, a green bolt in the middle and a green bolt with a small washer at the tip. I'm in the dunes right now and it's hitting the limiter. Any help would be much appriciated.
He's hitting limiter he needs too add weight to the tip pretty sure.
Sent from my SCH-I545 using Tapatalk
I just added a gram to the tip and it made a very small difference
Do you know how much heel weight or total weight you have ? sorry it's hard to guess what you have and what changes need to be made .
Dirty Dawg Dale
Leave the heal the way it is. Green bolt with a thin washer in the middle and alum bolt and thin washer on the tip. If you need any help tuning just give me a call 763-228-4345.
Thanks Dale!
1 - 8 of 8 Posts
