So my 2010 RZR S 1500 miles, ran on half oil for I don't know how long and developed this engine noise, everyone else was riding it when it started and didn't notice so I couldn't save it. I have already pulled the motor apart down to the crankshaft and can't find any obvious wear, metal shavings, or anything out of the ordinary. There is no apparent slop on the bearings or piston rods. Has anyone heard or seen this noise? Do I replace the crank or the top end? Pistons and valves are pretty black but sleeves look clean and unscratched. The noise almost seems to go away with higher RPM, and when i turn the clutch by hand I can pinpoint the exact spot where something inside the engine seems to knock, but I can't find it with the engine torn down.Any help?!? Has this happened to anyone else?
