Just installed the High Lifter 2" lift kit (with the stock shocks and springs) and out for a big ride this past Saturday. Our local trail riding always have some dirt and gravel roads and paved roads between the trails.
First comment, the 2" lift worked awesome. Did not drag on the rocks or fallen trees that I dragged across on the previous ride and the articulation was great to increase traction. So that part of the upgrade worked perfectly.
I researched before purchasing the lift kit. All upgrades on my '13 LE will be limited by budget, so this was one of the big factors for the High Lifter over the Racer Tech kit. I adjusted the front shock spring preloaders to the middle setting and removed the front sway bar and kept the rear sway on. On pavement at higher speeds, I was getting some body; to be expected. Also, the initial turn-in was quick, but also noticed alot of oversteer. So much that at higher speeds on pavement or gravel I had to be careful not to overshoot a turn and go ditch jumping. We chug along at 30-40 mph on the roads to the next trail.
So, I am looking for some remedies for the oversteer and slightly uncomfortable body sway at higher speeds. For now with no additional cost, crank the spring preloaders on the front to the stiffest setting? The rear is still at the softest setting; crank them up as well?
Future upgrades: HD springs, wheel spacers? Will these items remedy my concerns?
I appreciate any help and love this forum.
