1 - 9 of 9 Posts
I thought I had a bad bearing in the front left wheel. After removing the hub I discovered it had broken off inside the bearing carrier around the axle. I have removed the bearing carrier and taken out the sanp ring, but I am stuck. I cannot get the bearing ring to come out of the carrier.
Any ideas?
Put it in the freezer for awhile, this will shrink everything, then take it out and heat the outside of the carrier and drive it out with ease with a brass drift
how bad is it to change the rear wheel bearings i have a popping in the drivers rear ordered bearings from super atv gonna try to tackle it this weekend. any tips or pics would be helpfu. thanks
1 - 9 of 9 Posts
