1 - 2 of 2 Posts
Hi All,
I have noticed that many people on here have the same issue as me, my rear diff has let go. It appears like the Pinion gear nut has become loose and everything is broken. The following is going in the garbage: Pinion Gear, Crown wheel, Case, and coupling.
My question is, do any vendors sell an upgraded rear diff including all the gear set as I need a full replacement, everything is broken!!!:sad:
Also, I live in Australia so they need to be willing to ship to me.
I really hope someone can help me????
Thanks!!
parts not available,you have to get a new or used one,then you can put the parts in the hpd case,or if its stock put in holz motor mount lift kit(many failures caused buy case hitting frame) and use either hpd motor mount stiffeners(my choice) or the h.d. holz motor mounts,which are to stiff and cause other drive line issues imo. again unless your making big h.p. or drive it like a tasmanian devil stock case should hold up,if you do the mount lift and stiffener thing you should be fine as most failures traced back to case hitting frame
1 - 2 of 2 Posts
