1 - 3 of 3 Posts
Door latch does not line up. Need help
I have installed the drivers side door and everything lined up just right. The passenger door is installed but the latch does not line up at all. As you can see from the last pic, when the door is "fully" closed in it's natural position, the the latch pin would be so far inside the door frame that you could not drill. If i chose a normal hole location that would work for the latch, the door would not be in the frame at the top or the bottom.
This is a position you could get away with if you had room to drill a hole.
This the position that the door closes to naturally.
Thanks in advance for the help.
First thing to adjust will be the mount under the seat.
Loosen the T27 Torx bolt and pull the frame out away from the center of the car and tighten the bolt.
The next thing to do is add one of the anti-rattle strips that we provide in the hardware kit to the vertical face of that lower seat mount tab where the door frame makes contact with it.
That tab acts as a stop for the door frame.
Try that and let me know how it goes.
1 - 3 of 3 Posts
