my 08' rzr standard 800 is having issue, the front wheels will only pull in 4wd when in reverse! they will not pull when in high or low range(forward gears) with the switch on the 4wd light does light on the screen and stays lit, but front wheels will not pull in forward gears only reverse!
common issue?
would like to fix myself gettin ready to add superatv +5 "s" conversion long arm kit would be good time to pull front diff. and fix...
is this possibly the common sprague carrier fail? i plan to upgrade to the billitt superatv sprague if so...
thanks,
kevin
common issue?
thanks,
kevin
