1 - 2 of 2 Posts
I know I had a lot of problems with my throttle spring working its way off the spring sleeve so I figured I would share a cheap, easy and effective fix that takes no time at all. Just get a pair of channel locks and hold the spring over, It should stay then get a small hose clamp and tighten it down and your spring will no longer work its way off and keep your spring from warping.
I am still 16 in my head!
Good Idea. I have not had any problems with ours. I did put a backing plate under it, to keep it from wearing thru the Plastic Fire Wall.
1 - 2 of 2 Posts
