1 - 6 of 6 Posts
Discussion Starter · #4 ·
I just installed a wet sounds tower speakers and sub and also belt fan that plugs into tail lights checked all fuses and switched relay around but can't find problem thought it was chasing relay
I had a blown fuse changed and head lights work now would this have caused 4x4 to not work even though indicator light for 4x4 works
2014 RZR XP1000
I don't think the fuse would cuse the 4X4 not to work.
Maybe check the 4X4 switch to see if and of the wires came loose.
Discussion Starter · #6 ·
Tomorrow I will check to make sure I am getting 12 volt through the connector to the diff magnetic the diff has been totally rebuilt except for the casing all I can think is I am not getting proper bits to magnetic to engage and lock differential in
1 - 6 of 6 Posts
