1 - 19 of 19 Posts
Our winch mounting kit for the Polaris RZR is CNC laser cut and formed from 3/16" steel and comes in a durable black powder coat finish. Comes with Zinc plated hardware.
LIFETIME WARRANTY - you bend it we'll replace it!
Fits all winches with a 4-hole bolt pattern of 3" x 4.875"
ATR Polaris RZR Winch Mount $55
Winch Models it Fits:
WARN: U2500 / 12000 / A2500 / 1.5ci / 2.5ci / 2.5ce / 3.0ci / 3.0ce
WARN: RT15 / RT25 / RT30 / XT15 / XT25 / XT30
Ramsey: ATV2500 / ATV3000
Mile Marker: PE2500 VMX2.5
Superwinch: All newer 4-hole mounted units with a 3" x 4.875" bolt pattern
Champion: C10013 / C10014 / C10018
Venom: 2000 / 2500 / 3500 / 4000 / 4500X-H
Must Have Standard ATV Winch 4-hole bolt pattern of 3" x 4.875"
Must Have Standard ATV Fairlead bolt pattern of 4.875"
Discussion Starter #7
When are you going to make a mount for the RT40
I don't think it'll fit same place we mount the RT30. We now have a rear mount winch plate that fits the RT40. Only way we have to mount RT40 to the front would be a couple of the top mount winch bumpers we carry from EMP or Warn.
Discussion Starter #9
i had to get a 2" front receiver, then had a local guy extent it out and level it - uses my RT4.0 off my Ranger. works great and keeps the winch higher and out of the mud
Cool, do you keep it on the front or mounted in the back? We were thinking about making a place to mount winch cradle in bed area when not in use.
Jeremy
1 - 19 of 19 Posts
