1 - 2 of 2 Posts
We just released our new Heavy Duty Tie Rod kits for the RZR XP. We have them to fit your stock length suspension, +3 suspension, and -2 suspension.
The tie rod tubes are powdercoated textured black. Retail is $229 for the kit.
They are lighter than stock (almost a pound), and made from race proven materials. The best thing about them, and what seperates them apart from all the other kits, is the inner pivot point is in the same location as stock, so it will give you the least amount of bumpsteer possible. The kits that use hiem joints on both sides move that pivot further out so it can mount the hiem joint, but it creates more bumpsteer because they aren't pivoting where they should.
The tie rod tubes are made from 4130, and the machined stud and misalignment spacers are from tough 17-4 stainless, so they will last you plenty of abuse. The rod end is an oversized race proven 5/8" size with kevlar race for noise free operation.
Check them out!
+3 Version shown.
The inner pivot will be covered up by the steering rack boot just like your factory set up.
G-
1 - 2 of 2 Posts
