1 - 7 of 7 Posts
Jason,
I saw some some of your switch plates for the RZR-1000 on FB.
What options are there and prices?
Cliff, your Z1 kit comes with them. I send out LH and RH side with 1 gauge hole and 2 switches each. I would put boost and AFR in it for gauges minimum. Also would install a fuel pressure gauge too.
What color do you want them to be?
Black please.
I have a combo AFR and Boost gauge installed to the left of the steering wheel the dash already I was going to use.
I was thinking of putting oil pressure and water temp gauges in your plates.
Does the Z1 cluster display voltage or anything?
No not without putting it in diagnostic mode.
There is a company that can reprogram the cluster to do that. I will have to dig that info up.
Satin black right?
will the Vi-pec ecu determine what the gauge cluster displays?
satin black should be fine... anything in black should match.. LOL
Those are Pro Sport. No the ecu determines what is diaplays.
1 - 7 of 7 Posts
