1 - 20 of 34 Posts
Hey guys, just wanted to put it out there that we are the ones building the heavy duty front drive shafts that Trey is using in his 300HP cars. We are using chromoly tubing and balancing them afterwards. You can see it in the pictures the difference in the tubing. 50% increase in wall tubing and a little bigger in the diameter. They should hold anything you guys come up with for power. The price is $295 if you send us your shaft. $525 if we start with a new shaft. We have dealer pricing too. I will probably start keeping one around ready to go in stock length for those who need it NOW. We can build them in any length you need.
Just a reminder about our HD drive shafts that we build for ALL RZRs. If you are running a big HP RZR, you NEED this. The stock shaft is thin and not balanced. We can make any length if you are putting together a conversion too.
Discussion Starter · #7 ·
I am building a few this weekend for stock. So if anyone needs a drive shaft, I will do exchanges.
Discussion Starter · #9 ·
Will have one in stock for exchange later this week
Discussion Starter · #10 ·
I have one in stock right now that will fit 2008-2011 RZR and RZR S model. This will help the front diff live longer due to balancing.
Discussion Starter · #12 ·
I have one in stock right now that will fit 2008-2011 RZR and RZR S model. This will help the front diff live longer due to balancing. $295 exchange.
Discussion Starter · #19 ·
If you are running 70+ Might want to check your driveshaft to see if it wobbles like the rest we have seen. Hard of the pinion bearings.
1 - 20 of 34 Posts
