41 - 60 of 93 Posts
Re: Hawk Engineering XP Z1 DIY kit is getting started
Hey Hawk,
The XP Z1 Conversion looks awesome!
You guys do some really clean conversions. That Z1 motor on E-bay is a great price... Especially with such low hours. Somebody is going to get a great deal...
Keep posting the great pics..
Sand Sports Unlimited
Discussion Starter #42
I just finished up the XP Z1 early this morning. We are loading to go the Off Camber Rock Rally at Cloud 9. Here are a few pictures. Also about 90% done with the clutch cover. I am REAL HAPPY with how it has turned out!
The cage is temporary until I can get a nice one made. Question, what color do I make the cage when we get back next week? Orange or Blue???
Orange!
Looking good, bet it performs well too.
I really like the gauges.
Discussion Starter #45
Thanks Milos!
That looks sweeeeet! On the cage I would go orange to match the trailing arms and stuff.
This gives a whole new definition to "you wanna go for a ride in my rzr" if they only knew what they would be in for LOL
Discussion Starter #52
Yes air to air would be easy to do as well. Working out the details on price for the kit. Get that updated Monday.
Discussion Starter #54
Price for conversion kit is $5445.
Kit includes:
STM OD clutch our design
HD snowmobile belt
Primary clutch kit with low 2500 RPM engagement
Engine to tranny mounts
SS header with SS muffler, (2x O2 bungs installed)
Short aluminum intake
1 gallon aluminum oil tank
Remote oil filter kit w/Z1 water cooler
Air to water system
HV in tank fuel pump
Turbo oil and water fittings
Air intake tubing to bed
Up to 270 hp single ECU flash (your choice of boost level)
And of course our VERY detailed install instructions with pictures to help you out!
Options:
Custom made Z1 harness ready to install or we can modify your harness
OptiAir air cleaner
Enclosed belt cover with fan
Speedo calibration kit
NOTE: Our bed has nothing in it. You can fit a Polaris lock and ride box and a Yeti cooler in it!
Discussion Starter #56
$240 for one color powder coat. That is the center section only.
Discussion Starter #58
The whole center dash. Not the 2 narrow sides. Comes with the permanent mount plate, the center removable plate, SS mounting hardware.
Great Jason, just couple Q.'s if I can.
After my headache with kit where turbo was mounted to the frame, is the turbo mounted on the engine and move with it ?
The harness, I assume you will modify the Z 1 harness to will plug in to the RZR system ?
And last, I rather will go with air to air, do you plan to offer this option or will be possible to buy the kit without the air to water parts and figure out the piping after install ? Or do you think the turbo location will make this hard to do ?
THX milos
Discussion Starter #60
Turbo is mounted on engine. This way it goes where the engine goes so to speak. The muffler floats with the turbo by using the stock muffler hanger mounts.
I can make a harness to run the Z1 with gauge cluster on the dash. Or I can tell you what wires need to be connected and use the stock rzr harness for the dash stuff. I like to keep it clean and remove rzr harness. Then run a sub harness for the dash stuff.
The way I have the turbo setup would be easy for air to air and will take off the air to water option.
41 - 60 of 93 Posts
