1 - 3 of 3 Posts
NOOB
IS THE A FIX FOR HAVING TO PRESS TOO HARD ON BRAKE TO GET IT TO TURN OVER? ILL PRESS BRAKE SOMETIMES IT TURNS OVER SOME TIMES JUST CLICKS. I UNDERSTAND THERE IS A FOOT BRAKE SWITCH. DOES IT RELY ON PRESSURE? DO THEY MAYBE GET A LITTLE CLOGGED.
There is a pressure switch, yes , and if your brakes still work good and you’re not having troubles, then the pressure switch is a likely culprit. If your brakes are starting to lose performance, then you probably need to adjust the pads with the allen head on the back of the caliper (try that first, turn the screw in until the pads contact the rotor, then back off 1/2 turn), or replace the pads if they’re worn badly. Outside of that, you could have air in the lines, a leak, or a master cylinder starting to go out
1 - 3 of 3 Posts
