1 - 8 of 8 Posts
craigstumph
The Best Ties in the World!
Reusable
Grips very tight
70 lbs tensile strength
Heat stabilized
UV protected
Won't break when you tighten it up
Available in red, blue, and orange
Releasable, Rubber-Lined, protective cushioning cable ties to prevent wire and cable damage. Rubber-Lining prevents the need to over tighten to secure. Thus protecting wire insulation and conductors from damage. Resistant to Vibration: will not move around and cut wires or scratch off paint on installed surfaces. Faster installation and lower cost then separate cushioning materials.
Smooth corner low profile head with releasable, removable tab is designed to be low profile and provide high strength. Deep tooth engagement for high strength rating of 70 pounds. Deep tooth design made possible because of the spring like action of the Rubber lining. Easier to install with no need to pull really tight. Allow the Rubber to secure the wires at the precise bundle diameter needed rather then a crushing force of traditional ties.
Double sided grabber end allow great grip to position and pull the ties. The tall grabbers also allow the ends to be inserted prior to some installation scenarios. Deep tooth design gives a satisfying loud click from the extra tough locking head. If accidentally inserted simply move the release tab with your thumb and reposition. When repositioning or removal is no longer needed then user can flush cut off excess strap and the releasable tab flush with the retention head and this secures the Tie.
Rubber-Lining practically eliminates stress concentration points under tension, making the tie stronger for a longer life and more difficult installations. The Patented double Rubber-Lining bands grip and protect the bundle and slippage is reduced even on vertical installations. Rounded edges on the top of the tie also protect insulation, preventing sharp edges from damaging cables.
Ideally installed in Industrial MRO and OEM situations including and not limited to High Vibration and Stationary Production, Electrical Cabinets, Lawn and Garden, UTV Moto and ATV’s, RV, Marine, Aircraft, Heavy Equipment, and Trailers.
Ready to be used in areas where the environment requires Heat Stabilized and UV Protection.
Black UV Stabilized Nylon and Available in several rubber colors, Red, Blue, Orange
https://www.facebook.com/GripTies/videos/1996079697321122/?t=31
https://www.proutvparts.com/products/grip-lock-tie
Order online or PM!
craigstumph
Discussion Starter #8
How to Use
Set up everything that you want to secure prior to tightening, then tighten as necessary. The deep teeth design produces a satisfying click from the extra-tough locking head. If you are not ready to finalize the installation or your forgot "just one more wire" then use the release tab with your thumb, then pull out the tie.
After tightening, you can cut off excess strap and the releasable tab so that it's flush with the retention head.
You don't have to pull it crazy tight like other Ties. GripLockTies rubber lining practically eliminates stress concentration points under tension, making the tie stronger for a longer life.
Ideal for more difficult installations like industrial MRO and OEM situations, including high vibration and stationary production, electrical cabinets, lawn and garden, UTV Moto and ATVs, RV, marine, aircraft, heavy equipment, and trailers.
The patented double rubber-lining bands grip and protect the bundle, reducing slippage even when working on on vertical installations.
Ideally installed in ready-for-use areas where the environment requires heat stabilized and UV protection.
Black UV stabilized nylon from Dupont. Available in several rubber colors: red, blue, and orange.
1 - 8 of 8 Posts
