I just picked up a new 2012 RZR-S. When I am on a small incline and i change gears from park to reverse it grinds the gears before engaging. I am assuming this is not normal. Does anyone else have this problem? Thanks.
A parking brake is a good idea, but it will not help your situation. Have you changed any springs in the clutch?Its not a single clunk, it sounds like gears grinding for a few seconds spinning slowing down then it goes into gear. I feel like I am grinding down teeth. It sounds like the first time learning to drive a stick and the clutch is going out when you are 16.
