1 - 12 of 12 Posts
So I just finished greasing my wheel bearings. Just rolled over 700 miles and it took over 30 pumps per wheel. I could immediately feel the difference when I took it down the street after for a ride. Just wanted to pass on the info and let y'all know that is recommend doing it. It only took like 20 min per wheel. I bought the bearing greasers that allows you to keep the axel in. I plan on doing it a few times a year from now on.
2017 XP4T
Sent from my SM-N960U using Tapatalk
Ya they don’t seem to come packed with grease from the factory.
Berzerker
If you didn't put too much in and compromise the seals you might never have to do it again until you decide to change the bearings. I greased mine at 1000 miles and decided at 5900 miles that bearings and bushings and ball joints needed to be replaced. The bearings were still full.
I stopped pumping grease the second I could hear the grease coming through the seal. I was very conscious of not over filling them.
Good info, I've heard from others how dry the wheel bearings are, guess I better put this on the to-do list!
I bought the Havoc 44mm tool as well, it has 4 holes where grease comes out instead of one like some I’ve seen. 22 pumps after a dozen rides. 19’ XP4T.
1 - 12 of 12 Posts
