grease plugs
2.9K views 9 replies 7 participants last post by  scubadnv
i have a 2014 800rzr and have 2 grease plugs on the rear (a) arm that are 90 degree and i still can not get a grease gun on the grease fitting anyone got any ideas, i tryed to raise it but no help????
A picture would help us. You can think about replacing the zerk fittings with another type. At least three types are made 90 degree (like you have), 45 degree, and straight. They also come with different size threads so when going to buy others take one of you removed to make sure you get the right fit. Most bigger auto parts places have them.
Mike
I can grease the zerks labeled "A" with wheels on ground.
The zerks labeled "B" can be greased if you jack back of RZR up.
If sway bar is still attached, you may have to lift both wheels off of ground to get A-arms to droop enough to attach grease gun to zerk.
Use a needle fitting on your grease gun
17 1kS
That is correct... push the check ball in with the tip of the needle and grease away
17 1kS
