1 - 3 of 3 Posts
I’m taking a late season trip next weekend to the
dunes with my Turbo 4s. It will be a hot weather weekend. No need to run crazy big dunes but will run to Olds etc. via easy pathways. Will have 4 small adults on board. Will be running stock Coyote 32’s.
What’s the suggested air pressure, no bead locks?
Best gear selection- 4 high?
Due to the hot weather, remove belt cover or no?
Dynamax- best setting in dunes and sand hiway whooops?
Can it run long distance without cooling breaks etc?
Anything I missed?
Thanks.
2021 RZR Turbo S
I ran all season with the stock coyotes at 10 psi in 4 high no problem. I would just stick to morning and late afternoon rides and keep the belt cover on. We usually let it rest every 20-30 minutes of riding. Not sure about the Dynamix I have a velocity.
Run suspension in firm setting - with 4 people and speeds you can run most places - that is what you will want - maybe just switch to comfort in small chatter by your rig - otherwise firm all the time!
1 - 3 of 3 Posts
