I have participated in similar groups for other types of products. Polaris will be spending a good chunk of change and will listen to what your group has to say. Telling them how great their machine is will be wasting their time. Tell them what they need to change to make their product better.
One of the major design flaws that needs corrected ASAP is the amount of dirt dust snow mud water that ends up in the lap of the driver and inside the air box.
Seal up the gaps between the fire wall and the body so you dont have 1" diameter rocks landing in your lap.
Prefilter the air going into the air box so you dont have sand pour out when you remove the lid on the air box, keeps the clutches clean too.
Improve front plastics so every time you turn the steering wheel its not throwing stuff in the cab.
Pay closer attention to detail on everything including bolt torque, I have gound bolts that were barley snug on one side of the machine then the same bolts on the other side I had to use a 1/2" impact gun to break them loose, one side I found all the body screws stripped out and the other side they were ok.
Something has to be done with quality control it looks like they have none.
The whole wiring harness looks like it was installed by someone in highschool, parts of the harness pulled tight as a E string on a violin and other parts sagging and making contact with the exhaust system, low quality wire ties to secure a wiring harness for use off road you better take a look at what other MFG's are doing, I suggest HONDA havent had a wiring problem on their machines after 35+ years of ownership.
Unsealed unprotected electrical connections like on the brake switch that is same or less quality than the china buggys have.
Twice your .02 sheet metal screws holding my battery in place came loose now I have locktite them they seem to be holding, sheet metal screw into sheet metal to secure a battery, china quality at its best.
Do something better than a thin tube sandwich between a bolt and nut.
Shifter cable rubbing the drive shaft not even sure how that could possibly pass the design department.
Belt is rubbing on the belt guard I will have a hole their soon
ECM harness is in a huge strain just from gravity alone.
Radiator hose rubbing the frame
Why are we heating the gas tank? Pic also shows aluminum rubbing on steel with dirt and sand packed between them
Only some of the gas tank is protected from abrasion some places its still metal to plastic and signs of wearing a hole in the tank.
Wrong size hose clamp installed hose slides right off you smell raw gas leaking from connection.
Wrong hose clamp installed on radiator leaks coolant coolant level found low on 3 different RZR's this has been the wrong clamp for a long time.
Found same problem on 2009 RZR-S and a 2008 RZR 2010 RZR-S
Sheet metal screws keep coming loose battery hold down.
Battery box fills up with crap and it tries to wear a hole in your battery
Lid on the tool box does not seal.
Give me 200 bux for gas I will drive my RZR right to the factory and show them in person all kinds of things that needs refined, I would love to spend a few days going over this thing with the design guys.
I have seen much more on this thing most vendors has pointed out the problems with their LONG list of fixes (parts) to cure most the minor design flaws.
