1 - 1 of 1 Posts
· Premium Member
MotoSport.com has had great reviews of the Power Commander 5 from Dynojet. The Power Commander allows you to really tune your motor and fuel delivery to get the optimal power delivered from your ATV/UTV. So if you are looking for a bolt on accessory that you will instantly feel a huge difference then the Power Commander 5 is the device for you!
Here are some of the features:
Reduced size from PCIII USB (less than half of the size of PCIII).
USB powered from computer (9V adapter is no longer needed for programming).
Two-position map switching function built in (map switch not included).
Gear/speed input (allows for map adjustment based on gear and speed).
Analog input (allows user to install any 0-5V sensor and build an adjustment table based on its input such as boost or temperature).
With gear-position input connected, the PCV is capable of allowing each cylinder to be mapped individually and for each gear.
Unit has a -100/+250% fuel change range (up from -100/+100%), which allows more adjustment.
10 throttle position columns (up from nine on PCIII USB).
Enhanced "accel pump" utility (increased adjustment and sensitivity ranges).
MotoSport.com Price: $359.95
1 - 1 of 1 Posts
