1 - 20 of 28 Posts
Super Moderator
This post will be specifically related to gear reduction information only. If you have a specific question about gear reduction please start a post with your question. Let's keep this informational only.
I'm going to be compiling all the gear reduction information for all models into this post. I was in the process of modifying the original Gear Reduction Spreadsheet when @RWB713 told me he had an updated version. The updated version already had the changes I was adding (final drive ratios). So a huge thanks to Richard!. This will be a work in progress as there is a LOT of data to add. The new spreadsheet covers all model through 2019. If you have tooth counts for 20/21 models please let me know so I can enter the data in the spreadsheet.
This thread should provide all the information for anyone looking to do a gear reduction. It will evolve to include, data, part sources, videos, etc....
Update 3/8/21:
Here is a link to the new Gear Reduction Spreadsheet: RZR Forum
New features include final drive ratio, front/rear drive ratio, MPH calculations, tire change calculation, total reduction with gear/tire combinations.
Please let me know if you have trouble downloading the spreadsheet. I will post instructions on how to use the spreadsheet later.
668637
Once again, If you have tooth counts for 20/21 models please let me know so I can enter the data in the spreadsheet. List them according to the spreadsheet lettering, example: 1A - 42T
667628
667629
Super ATV Gear Reductions
Super ATV offers several gear reduction options:
667749
667750
667751
Super Moderator
Discussion Starter · #2 · (Edited)
Turbo Model Trans: XPT, XPT4, XPTS, XPT4S, RS1 (Only minor differences in Pro XP & ProXP4 data will be later)
Note: 2016 XPT/XPT4 & 2017 XPT4 already have a 67/25. Some models have a one piece input shaft and some do not. I will list the differences later.
There are a few different options available and depends on whether you start with a 2 or 4 seat trans: This ONLY applies to OEM gears. I will update aftermarket gearing late.
4 seater 31/61 low gear & 43/22/31 Input shaft
2 seater 29/64 low gear & 42/22/29 Input shaft
Turbo 4 Seater Options:
Ace 325 Gear Set:
#3235450 48T Stage 2 Gear
#3235451 25T Reverse Gear Shaft
Net reduction: 12.69% L, H & R
XPT2 low gear set
#3235774 64T Low Gear
#3235989 29T Low Gear
Net reduction: 12.15% Low Only
Ranger low gear set
#3235232 67T Low Gear
#3236132 25T Low Gear
Net reduction: 36.19% Low only
Ranger low gear set & Ace 325
Net reduction: 53.48% Low : 12.69% H & R
XPT2 low gear set & Ace 325
Net reduction: 26.39% Low : 12.69% H & R
Ranger low gear set & Ace 325 + XPT2 Input shaft:
#3235987 Input Shaft (42/22/29)
#3235234 53T High Gear
Net reduction: 53.44% Low : 17.59 % High : 12.69% Reverse
Turbo 2 Seater Options:
Ranger low gear set
Net reduction: 21.43 % Low Only
Ace 325 gear set
Net reduction: 26.54% L, H & R
Ranger low gear set & Ace 570
#3235380 27T Stage 2 Gear
#3235381 46T Reverse Gear Shaft
Net reduction:36.36% Low : 12.29% H & R
Net reduction: 53.67% Low : 26.54% H & R
Ranger low gear set & Ace 325 + XPT4 Input shaft:
#3235988 Input Shaft (43/22/31)
#3235233 52T High Gear
Net reduction: 53.67% Low : 21.27 % High : 26.54% Reverse
XP1000 Trans: Note: TRE & HL Models already have a 67/25 Low & DBL Reverse Chain (Generic - some years may differ - use spreadsheet to determine exact reduction)
Low reduction uses the HL Double reverse chain & Input Shaft (other options later)
Note: 2014/15 models require HL input shaft & 16+ Secondary clutch.
XP 1000 2 Seater Options:
#3235380 27T Ace 570
#3235381 46T Ace 570
Net reduction: 12.29% Low :12.29% High : 12.29% Reverse
#3235451 25T Ace 325
#3235450 48T Ace 325
Net reduction: 26.54% Low : 26.54% High : 26.54% Reverse
#3235764 HL Input Shaft 42T/20T/25T
#2235633 HL DBL Chain
#3235762 Sprocket 48T
#3235232 low Gear 67T
Net reduction: 21.34% Low Only
#3235633 HL DBL Chain
Net reduction: 36.36% Low :12.29% High : 12.29% Reverse
Net reduction: 53.67% Low : 26.54% High : 26.54% Reverse
XP 1000 4 Seater Options:
Net reduction: 12.69% Low :12.69% High : 12.69% Reverse
#335633 HL DBL Chain
Net reduction: 24.00% Low Only
Net reduction: 39.74% Low : 12.69% High : 12.69% Reverse
I will continuously update the above info as I get to it, this is not a complete list yet. If you see an error please let me know.
@Crash City SxS Need your help my friend with the Pro XP models. I know you've down a couple and the intermediate gearing is different than a XPT. Can you give me the #s so I can put them in the spreadsheet and options above.
I didn’t count them when we had them apart but let me do some digging and see if I can find anything.
Turbo Model Trans: XPT, XPT4, XPTS, XPT4S, RS1 (Pro XP & ProXP4 data will be later)
4 Seater Options:
Ace 325 Gear Set:
Ranger low gear set
2 Seater Options:
Ranger low gear set
Ace 325 gear set
This list is for Turbo machines only correct? Do you have a compiled list with OEM part #s for the regular XP1000’s 2 and 4 seat available?
I’ve been reading a lot lately on the stage 3 gear reduction. What’s your thoughts on that?
Super Moderator
Discussion Starter · #8 · (Edited)
I assume you mean the 10/19% reductions from Optimum Offroad? I believe they were purchased by a larger company and those gears are no longer available.
SATV also makes a Stage 3 set. I will add in all the aftermarket options once I get the OEM stuff finished.
Super Moderator
Discussion Starter · #9 ·
Updating the spreadsheet to include MPH, Gear Reduction MPH for H/L/R, & Tire size changes. I should have it done and updated shortly.
Need info on Pro model if you have it.
2014 XP 1000 on portals
Needs a note in the xp1k section about the highlifter low range only reduction not working on the 2014-15 models? Also on those models do you just need to switch to a 2016 secondary clutch to make that work?
Super Moderator
Discussion Starter · #12 ·
Note added for 14/15 models
Still working on it. ;)
I believe a 16+ secondary is all that is required but I need to dig into when I have time.
Copy and paste error, should be #3235633 HL DBL Chain
When I look up all the info on parts for the 36.36% Low :12.29% High : 12.29% Reverse. trying to figure out if all of the sprokets are on the list for the double reverse chain. The part number for the chain only show the chain and no sprockets. Is all of the necessary hardware to do the double reverse chain on this list?
Thanks for taking the time to do all of this.
Sorry if I missed this but ... Any updates on the Pro XP gearing?
Is the Pro XP basically geared the same as the XPT or did Polaris improve / lower it some?
Super Moderator
Discussion Starter · #18 ·
It's only minor differences if any, still working through stuff.
I’ve got a buddy going to reduce his pro but he doesn’t know for sure when. After the cloud of belt smoke on big widowmaker at Hollerwood this weekend it may be sooner than he was planning lol.
@RZR_Joe are you still needing tooth counts in a pro?
Super Moderator
Discussion Starter · #20 ·
Yes sir.
BTW - headed to Black Mountain this weekend (y)
1 - 20 of 28 Posts
