Yessir, I can put together 47% Low, 26% Reverse, 22% High. If that High is not a problem then you will love the LowHave you had a chance to check the gearing on the 18 Turbo S? I am picking one up and want to do a low gear swap to at least 47%. I do mostly rock crawling at Sand Hollow and Moab.
I have a 900 w Carls’ 47% on 30’s, the crawling and creeping is amazing. Typing this now from day one at windrock TN and im yet to really test it.Have you had a chance to check the gearing on the 18 Turbo S? I am picking one up and want to do a low gear swap to at least 47%. I do mostly rock crawling at Sand Hollow and Moab.
Thank you very much sir. I always love a pat on the back. Please keep me posted as you test
Plenty of info on gear reduction on the web. If you have a press, you can do it yourself. Lots of shops do them as well. Replace the bearings if you crack it open.I know this old but can't find any answers
I can't pm you I would like to take more about re gearing a 2016 rzr turbo
What size tire? What elevation? What belt? Stock clutches? How many miles on the machine? Are you keeping your clutches clean? Scotch bright the sheeves during belt changes?What's you experience with ratios. I'm trail riding with a turbo 1000 and low is 2 slow and in high I get belt burn? Thank you for the help
