1 - 2 of 2 Posts
2017 RZR 1000 XP, Gauge cluster not working, coming on, nor lighting up. Showed Over Voltage before it went out...
So far Ive replaced the following:
ENTIRE wiring harness, front to back
New battery leads to starter and to accessory block
Cleaned and Regrounded the ground cable
Load test on and charged Battery
Swapped out gauge cluster with "known to work" gauge cluster
New starter Solenoid (just because)
Replaced all relays and fuses
New Voltage Mosfet Regulator from RMSTATOR
New ignition coil and wires (just because)
Tested the pins (wire harness side) for 12 volts
Need help please!!!
1 - 2 of 2 Posts
