1 - 10 of 10 Posts
craigstumph
Free Shipping in the Lower 48
PM or Order online
GATES G-FORCE™ REDLINE™ CVT BELT
Gates G-Force™ RedLine™ CVT Belts are engineered from a patented, fiber-reinforced Ethylene Elastomer compound, providing maximum transverse stiffness and unmatched heat resistance which allows for increased durability, greater load-carrying capability and a higher effective operating temperature.
WHY G-FORCE™ REDLINE™ CVT BELTS?
  • Greater heat resistance and recovery, even under severe duty cycles
  • Optimized, patented EE compound maximizes axial stiffness enabling belts to run at higher continuous torques or loads
  • Innovative design results in better acceleration, higher top speeds, less speed ratio and energy loss in extreme off-road environments
  • Improved durability, crack and wear-resistance means a longer-lasting, high-performance power transmission belt for the most demanding applications
  • Reduced Environmental Risk — made without harmful chlorinated compounds
FEATURES & BENEFITS
  • First on the market to utilize Ethylene Elastomer compound to address the needs of larger SxS and high-horsepower ORVs in tough riding conditions
  • Next-generation EE compound offers maximum transverse stiffness and heat resistance, resulting in higher load capacity, higher peak torque capacity, less “heat fade” and less speed loss
  • Delivers 75% greater dynamic axial stiffness on average, up to 50% lower speed losses and better recovery from temperatures up to 338°F (170°C) without power loss
  • Unmatched Temperature Capability – Runs cooler, resists glazing for better recovery and reduced cracking/chunking out after running at temps exceeding 300°F
  • Extended Belt Life – Belt life increased 100-300% versus aftermarket competitive belts in severe duty lab test conditions and in field testing
  • Higher Power Capacity – Reduced speed (rpm) loss by 50% under high loads and increased load capacity by >10% compared to other aftermarket belts
643569
craigstumph
Discussion Starter · #4 ·
1 - 10 of 10 Posts
