1 - 20 of 36 Posts
called up futv and ordered up a set of their new sliders in 3/8ths. had them 3 days later.
you get the 2 sliders, 8 self tapping bolts, and a pair of futv decals
the bottom of the slider measures right at 3.5" (except the very front where it tapers in). this will mainly be important to those not running a full skid. those running a futv skid will mount these in between the body and the belly skid.
in the back the sliders are about 5.5" tall
and in the front they are just over 3" tall
i will be replacing polaris sliders. the drawbacks of the polaris sliders is their weight and they cut into your ground clearance a bit. here is a pic of the the installed polaris slider from underneath the vehicle
you lose about 1.5" of ground clearance near the outside of the rzr with the polaris sliders
install couldnt be easier. these are the definition of keeping it simple. you just remove the 4 outermost bolts that hold the belly skid on (also hold the body to the frame for those not using these with a futv or similar belly skid) and place the slider between the body and the belly skid. install with the 4 longer self tapping bolts provided with the slider
instead of the 1.5" of clearance lost with the polaris slider, you only lose clearance in the amount of the sliders thickness, which is 3/8ths of an inch in my case.
pic from the side. they follow the line of the door opening perfectly
the front and rear are cut to clear the rzr s fenders
front
rear
from the top you can see they have a small amount of space between the slider and the body
and finally, the weight savings. per side the polaris sliders are 14 lbs with mounting hardware
the futv skids are 4lbs per side..
not a bad way to drop 20lbs. the sliders are well made, which is what you can expect with everything from futv. will be going out to test them soon. i dont have a hard time finding rocks around here
thx again futv
Geezer with Joey
Thank you for that effort. Great work! Did you measure overall width (widest point) after install?
if i measure from the top edge at the rear-most point of each slider i get between 50 and 50.5"
it is a bit difficult to measure. since i have half doors i have to eyeball it from above the slider and they slant outwards slightly
i thought this might help for those wondering about how they affect the overall width.
here is the measure ment at the top edge at the widest point (rear of the slider)
they add an inch to each side at their widest point
Really great review.
If my plastics weren't so mangled already, I'd consider a set. Definitely will after I replace my plastics.
I just wanna ride
Great job Kevin. I think I need to get a set of those.
Installed the 1/2" sliders last night. Very form fitting, great product FUTV.
New set of those Polaris ones in the shed, never installed....
rzr(s)hroom--what kind of 1/2 doors are those? Do they help keep some of the mud off your legs? I'm looking for a little protection from the mud splatter/shower, but don't want to put on full doors
Discussion Starter · #18 ·
here you go...
RZR, RZR-S Half Door Kit [613021] - $169.00 : Holz Racing Products, Race Proven Engineering
they do a good job of keeping your legs in the vehicle and do reduce the amount of mud/water that gets thrown into the vehicle. i also run asylum flares on the front and between them and the doors we stay pretty clean
we didnt want to go with doors because we like the open feeling of the rzr (if i wanted full doors and a cab i woulda stuck to a jeep) and with the holz panels we retain that
Is anybody running these sliders with the stock skid plate? If so I would love to see some pics....just wondering how they look underneath with the stock skid.
I waited too long to replace the stock plate and ran the Polaris sliders. Don't make the same mistake. It doesn't make any sense to protect the sides and trash underneath.
Eli
1 - 20 of 36 Posts
