1 - 7 of 7 Posts
I have a new xp turbo dynamic 4 door. where is a good place for extra fuse box?
also where to run the wires from back to front and down etc--not much room anywhere
like the early models.. thanks
2020 900 Trail Fox Edition
I mounted mine in the same place only difference I Mfg my mounting plate from sheet metal (cheap). I have no idea about the wires good luck. Post a pic when you complete your mod. JMHO
I mounted mine directly on the firewall. Hindsight, I might’ve made a bracket to mount it horizontally like some of the others, but this was done before I knew that I might want to put a washer res there.
Motor vehicle Hood Automotive tire Auto part Trunk
  • Like
Reactions: markgam
1 - 7 of 7 Posts
