I recently had rough running issues and narrowed it down to the fuel pump, it was putting out only 25 psi and immediately losing pressure when the pump was shut off.
I pulled the pump assembly, and then pulled the pump itself out and bench tested it. It tested at 58-60 psi. re-assembled it, and what I could see is that the pump itself was pushing down inside the assembly, causing the pump outlet to slip part way out of the green O ring in the cage. At the bottom of the cage is the foam insulator - it was pretty squished but didn't look out of place.
Anyway, the 'fix' was to shim (with 3 layers of inner tube cut in to discs) the bottom of the pump in the cage so that it can't slip down and out of the O ring. (I didn't take pics, so had to grab this one off the internet).
Has anyone come across an issue like this before? FWIW, it now works perfectly. Though I wonder how long the rubber will last in there and whether I am missing a part somewhere.........
