1 - 7 of 7 Posts
Has anyone had the problem of the fuel gauge flashing? My check engine light is on at and idle also which is a separate problem and it has a code 22 which is the tps, :question:what is the best way to correct that problem?
my fuel gauge quit coming on altogether.. idk why.. have yet to find out.. searching the reason when i read yours.. let me know if you find out anything, and I will do the same.
Is the sending unit in the tank on the fuel pump or what and it doesn't wanna idol right and when u suddenly hit the gas it cuts out I've ran into this problem once before and the Polaris shop said it was the fuel pump and it was running lean that's why it was flashing and they changed the pump and it did great for a while now it is doin the same thing again that's why I thought it may be the fuel pump and I bought a new one from the local parts store to do the swap I'm just tryn to figure out if its the fuel pump or not
1 - 7 of 7 Posts
